Podczas rysowania poligonów na nowej warstwie wywala mi błąd i zamyka QGISa.
Raport z tego błędu:
Cytat Python Stack Trace
Windows fatal exception: access violation
Thread 0x00005190 (most recent call first):
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\selectors.py”, line 314 in _select
r, w, x = select.select(r, w, w, timeout)
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\selectors.py”, line 323 in select
r, w, _ = self._select(self._readers, self._writers, , timeout)
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\socketserver.py”, line 235 in serve_forever
ready = selector.select(poll_interval)
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\threading.py”, line 1012 in run
self._target(*self._args, **self._kwargs)
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\threading.py”, line 1075 in _bootstrap_inner
self.run()
File “C:\PROGRA~1\QGIS34~1.4\apps\Python312\Lib\threading.py”, line 1032 in _bootstrap
self._bootstrap_inner()
Current thread 0x0000230c (most recent call first):
Stack Trace
geos::geom::Triangle::operator= :
initGEOS :
GEOSGeom_extractUniquePoints_r :
QgsTracer::initGraph :
QgsTracer::findShortestPath :
QgsMapToolCapture::tracingMouseMove :
QgsMapToolCapture::cadCanvasMoveEvent :
QgsMapToolAdvancedDigitizing::canvasMoveEvent :
QgsMapCanvas::mouseMoveEvent :
QWidget::event :
QFrame::event :
QGraphicsView::viewportEvent :
QCoreApplicationPrivate::sendThroughObjectEventFilters :
QApplicationPrivate::notify_helper :
QApplication::notify :
QgsApplication::notify :
QCoreApplication::notifyInternal2 :
QApplicationPrivate::sendMouseEvent :
QSizePolicy::QSizePolicy :
QGuiApplicationPrivate::processMouseEvent :
QWindowSystemInterface::sendWindowSystemEvents :
QEventDispatcherWin32::processEvents :
qt_plugin_query_metadata :
QEventLoop::exec :
QCoreApplication::exec :
main :
BaseThreadInitThunk :
RtlUserThreadStart :
QGIS Info
QGIS Version: 3.40.4-Bratislava
QGIS code revision: 4dd7d7e969
Compiled against Qt: 5.15.13
Running against Qt: 5.15.13
Compiled against GDAL: 3.10.2
Running against GDAL: 3.10.2
System Info
CPU Type: x86_64
Kernel Type: winnt
Kernel Version: 10.0.26100
Czy jest ktoś w stanie powiedzieć co się dzieje ? Jak zaradzić temu błędowi ?
Pozdrawiam
